Ana içeriğe geç
Cuisinart DCC-3200 Hot Plate Replacement
Neye ihtiyacın var
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: adım 1, 1 resimden 1.
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: adım 2, 1 resimden 1.
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: adım 3, 2 resimden 1. Cuisinart DCC-3200 Hot Plate Replacement: adım 3, 2 resimden 2.
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: adım 4, 1 resimden 1.
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hamad Khan
385 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-3, Botvin Spring 2016 UMass Dartmouth, Team 8-3, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G3
3 Üyeler
5 Yorum
Where can one purchase the burner plate?
john Vet - Yanıt
Same question as John Vet
Bob Stimson - Yanıt
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - Yanıt
Same question: where can we purchase the burner plate?
Cresny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 27
Son 30 gün: 111
Her zaman: 4,849
