Ana içeriğe geç
Cuisinart DFP-14BCN Back Casing Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Cuisinart DFP-14BCN Back Casing Replacement, Bowl: adım 1, 3 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement, Bowl: adım 1, 3 resimden 2. Cuisinart DFP-14BCN Back Casing Replacement, Bowl: adım 1, 3 resimden 3.
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Back Casing Replacement: adım 2, 1 resimden 1.
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Back Casing Replacement: adım 3, 3 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement: adım 3, 3 resimden 2. Cuisinart DFP-14BCN Back Casing Replacement: adım 3, 3 resimden 3.
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Back Casing Replacement: adım 4, 1 resimden 1.
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Back Casing Replacement: adım 5, 3 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement: adım 5, 3 resimden 2. Cuisinart DFP-14BCN Back Casing Replacement: adım 5, 3 resimden 3.
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Back Casing Replacement, Back Casing: adım 6, 2 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement, Back Casing: adım 6, 2 resimden 2.
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Back Casing Replacement: adım 7, 2 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement: adım 7, 2 resimden 2.
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Back Casing Replacement: adım 8, 3 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement: adım 8, 3 resimden 2. Cuisinart DFP-14BCN Back Casing Replacement: adım 8, 3 resimden 3.
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Back Casing Replacement: adım 9, 2 resimden 1. Cuisinart DFP-14BCN Back Casing Replacement: adım 9, 2 resimden 2.
    • Lift off the back casing by raising it upward.
Sonuç
Sonya Dick
352 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 65
