Ana içeriğe geç
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement
Neye ihtiyacın var
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement, Internal Wiring: adım 1, 1 resimden 1.
    • Remove the four screws from the bottom of the processor with a Philips Screwdriver.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: adım 2, 1 resimden 1.
    • Remove the bottom casing of the processor.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: adım 3, 1 resimden 1.
    • If any wires are frayed, cut them off where they are connected by wire nuts.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: adım 4, 1 resimden 1.
    • Detach the wire nut from the other connected wires.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: adım 5, 1 resimden 1.
    • Replace the bad wire with a new one of the same gauge.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: adım 6, 1 resimden 1.
    • Strip the new wire to the same length as the other wires and connect them to a wire nut.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Riley Carns
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-1, Lancaster Winter 2015 Cal Poly, Team 24-1, Lancaster Winter 2015 üyesi
CPSU-LANCASTER-W15S24G1
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 965
