Ana içeriğe geç
Cuisinart DLC-8F Automatic Circuit Breaker Replacement
Neye ihtiyacın var
  1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: adım 1, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: adım 1, 2 resimden 2.
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 2, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 2, 2 resimden 2.
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 3, 1 resimden 1.
    • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
  4. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 4, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 4, 2 resimden 2.
    • Lift off the cable retaining
  5. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 5, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 5, 2 resimden 2.
    • Pull apart the two wires of the power cable at their connections as shown.
  6. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 6, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 6, 2 resimden 2.
    • Lift out the cable.
  7. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: adım 7, 3 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: adım 7, 3 resimden 2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: adım 7, 3 resimden 3.
    • Pull out the power cable screw stand with your hand.
  8. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 8, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 8, 2 resimden 2.
    • Remove the two 15 mm Phillips #2 screws on the automatic circuit breaker.
  9. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 9, 2 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 9, 2 resimden 2.
    • Pull out the automatic circuit breaker with your hand.
  10. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 10, 3 resimden 1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 10, 3 resimden 2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: adım 10, 3 resimden 3.
    • Pull off the three wires by grabbing from the base of the wire.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Colman
573 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-6, Banghart Winter 2017 Cal Poly, Team 8-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 681
