Ana içeriğe geç
Cuisinart DLC-8F Power Switch Assembly Replacement
Neye ihtiyacın var
  1. Cuisinart DLC-8F Power Switch Assembly Replacement, Power Switch Assembly: adım 1, 2 resimden 1. Cuisinart DLC-8F Power Switch Assembly Replacement, Power Switch Assembly: adım 1, 2 resimden 2.
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 2, 2 resimden 1. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 2, 2 resimden 2.
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 3, 3 resimden 1. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 3, 3 resimden 2. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 3, 3 resimden 3.
    • Pull out the three wires coming out of the power switch assembly by firmly grabbing the base of the wires and pulling.
  4. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 4, 2 resimden 1. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the three 12 mm Phillips #2 screws from the power switch assembly.
  5. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 5, 2 resimden 1. Cuisinart DLC-8F Power Switch Assembly Replacement: adım 5, 2 resimden 2.
    • Pull out the power switch assembly with your hand.
    • This might take some jiggling and effort.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Colman
573 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-6, Banghart Winter 2017 Cal Poly, Team 8-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 501
