Ana içeriğe geç
Cuisinart DLC-8F Safety Switch Replacement
Neye ihtiyacın var
  1. Cuisinart DLC-8F Safety Switch Replacement, Safety Switch: adım 1, 2 resimden 1. Cuisinart DLC-8F Safety Switch Replacement, Safety Switch: adım 1, 2 resimden 2.
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Safety Switch Replacement: adım 2, 2 resimden 1. Cuisinart DLC-8F Safety Switch Replacement: adım 2, 2 resimden 2.
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Safety Switch Replacement: adım 3, 2 resimden 1. Cuisinart DLC-8F Safety Switch Replacement: adım 3, 2 resimden 2.
    • Remove the two 14 mm Phillips #2 screws holding in the safety switch bracket.
  4. Cuisinart DLC-8F Safety Switch Replacement: adım 4, 2 resimden 1. Cuisinart DLC-8F Safety Switch Replacement: adım 4, 2 resimden 2.
    • Pull out the safety switch bracket with your hand.
  5. Cuisinart DLC-8F Safety Switch Replacement: adım 5, 2 resimden 1. Cuisinart DLC-8F Safety Switch Replacement: adım 5, 2 resimden 2.
    • Remove the two 19 mm Phillips #2 screws holding the safety switch in the bracket.
  6. Cuisinart DLC-8F Safety Switch Replacement: adım 6, 3 resimden 1. Cuisinart DLC-8F Safety Switch Replacement: adım 6, 3 resimden 2. Cuisinart DLC-8F Safety Switch Replacement: adım 6, 3 resimden 3.
    • Pull off the three wires on the safety switch with your hand by firmly grabbing the wires at the base.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Colman
573 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-6, Banghart Winter 2017 Cal Poly, Team 8-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G6
4 Üyeler
Bir Yorum
how do you overrid the safty switch? What wires do you connect?
Roger Nelson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 737
