Ana içeriğe geç
Cuisinart Griddler GR-4N Cooking Surfaces Replacement
Neye ihtiyacın var
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: adım 1, 2 resimden 1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: adım 1, 2 resimden 2.
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: adım 2, 1 resimden 1.
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: adım 3, 1 resimden 1.
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: adım 4, 1 resimden 1.
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: adım 5, 2 resimden 1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: adım 5, 2 resimden 2.
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kayla Londono
632 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G12
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 4,099
