Ana içeriğe geç
Cuisinart Mini-Prep DLC-2A Button Replacement
Neye ihtiyacın var
  1. Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: adım 1, 2 resimden 1. Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: adım 1, 2 resimden 2.
    • Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
  2. Cuisinart Mini-Prep DLC-2A Button Replacement, Button: adım 2, 1 resimden 1.
    • Locate the Button Panel inside the blender.
    • Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
  3. Cuisinart Mini-Prep DLC-2A Button Replacement: adım 3, 3 resimden 1. Cuisinart Mini-Prep DLC-2A Button Replacement: adım 3, 3 resimden 2. Cuisinart Mini-Prep DLC-2A Button Replacement: adım 3, 3 resimden 3.
    • Locate the black box held in place on the panel.
    • Using your Spudger, wedge the black box out of its place to uncover the button
  4. Cuisinart Mini-Prep DLC-2A Button Replacement: adım 4, 2 resimden 1. Cuisinart Mini-Prep DLC-2A Button Replacement: adım 4, 2 resimden 2.
    • Once the black box is out of place, use your finger to push out the button.
    • Now replace the old button with your newly acquired button.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Xavier Tapia
144 İtibar
1 Kılavuz yazıldı
Bir Yorum
Hi,
Where’d you get the new buttons?
Mark B - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 274
