Ana içeriğe geç
Cuisinart Mini-Prep DLC-2A Motor Replacement
Neye ihtiyacın var
  1. Cuisinart Mini-Prep DLC-2A Motor Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: adım 1, 2 resimden 1. Cuisinart Mini-Prep DLC-2A Motor Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: adım 1, 2 resimden 2.
    • Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
  2. Cuisinart Mini-Prep DLC-2A Motor Replacement, Motor: adım 2, 3 resimden 1. Cuisinart Mini-Prep DLC-2A Motor Replacement, Motor: adım 2, 3 resimden 2. Cuisinart Mini-Prep DLC-2A Motor Replacement, Motor: adım 2, 3 resimden 3.
    • Remove the three screws that hold the motor to the top case using a Phillips #1 screwdriver.
  3. Cuisinart Mini-Prep DLC-2A Motor Replacement: adım 3, 3 resimden 1. Cuisinart Mini-Prep DLC-2A Motor Replacement: adım 3, 3 resimden 2. Cuisinart Mini-Prep DLC-2A Motor Replacement: adım 3, 3 resimden 3.
    • Pull out the metal piece from the casing.
    • Pull apart the plastic casing that contains the rod.
    • Take off the plastic gears.
  4. Cuisinart Mini-Prep DLC-2A Motor Replacement: adım 4, 2 resimden 1. Cuisinart Mini-Prep DLC-2A Motor Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to take off the screws that hold the white plastic to the metal piece.
    • Pull apart the white plastic from the metal piece.
  5. Cuisinart Mini-Prep DLC-2A Motor Replacement: adım 5, 1 resimden 1.
    • Use an electric screwdriver with a Phillips #1 head to take off the top metal piece.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 758
