Ana içeriğe geç
Cuisinart Smart Stick CSB-75 Electrical Cord Replacement
Neye ihtiyacın var
  1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: adım 1, 3 resimden 1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: adım 1, 3 resimden 2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: adım 1, 3 resimden 3.
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 2, 2 resimden 1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 2, 2 resimden 2.
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 3, 3 resimden 1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 3, 3 resimden 2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 3, 3 resimden 3.
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 4, 3 resimden 1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 4, 3 resimden 2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 4, 3 resimden 3.
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 5, 3 resimden 1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 5, 3 resimden 2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: adım 5, 3 resimden 3.
    • Refer to these steps on Soldering to replace the electrical cord in the smart stick.
    • Be careful when soldering; it gets very hot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan Robinson
614 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Wollert Fall 2015 USF Tampa, Team 16-2, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 2,276
