Ana içeriğe geç
Cuisinart TOA-60FR Light Switch Spring Replacement
Neye ihtiyacın var
  1. Cuisinart TOA-60FR Light Switch Spring Replacement, Outside removal: adım 1, 1 resimden 1.
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 2, 2 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 3, 3 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 3, 3 resimden 2. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 3, 3 resimden 3.
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 4, 2 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 4, 2 resimden 2.
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 5, 3 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 5, 3 resimden 2. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 5, 3 resimden 3.
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: adım 6, 2 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: adım 6, 2 resimden 2.
    • Unscrew these two screws.
  7. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 7, 2 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 7, 2 resimden 2.
    • Pull back piece off of the clicker.
  8. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 8, 2 resimden 1. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 8, 2 resimden 2.
    • Pray open the clicking piece with a metal spudger.
  9. Cuisinart TOA-60FR Light Switch Spring Replacement: adım 9, 1 resimden 1.
    • Replace the broken spring with a new spring
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 62
