Ana içeriğe geç
Cuisinart TOA-60FR Lightbulb Replacement
Neye ihtiyacın var
  1. Cuisinart TOA-60FR Lightbulb Replacement, Outside removal: adım 1, 1 resimden 1.
    • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
  2. Cuisinart TOA-60FR Lightbulb Replacement: adım 2, 2 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
    • Pull off the back panel.
  3. Cuisinart TOA-60FR Lightbulb Replacement: adım 3, 3 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement: adım 3, 3 resimden 2. Cuisinart TOA-60FR Lightbulb Replacement: adım 3, 3 resimden 3.
    • Flip the oven upside down.
    • Use a spudger to pull out the grey stoppers.
    • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
  4. Cuisinart TOA-60FR Lightbulb Replacement: adım 4, 2 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement: adım 4, 2 resimden 2.
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
  5. Cuisinart TOA-60FR Lightbulb Replacement: adım 5, 3 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement: adım 5, 3 resimden 2. Cuisinart TOA-60FR Lightbulb Replacement: adım 5, 3 resimden 3.
    • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
  6. Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: adım 6, 2 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: adım 6, 2 resimden 2.
    • Remove these two 12.8 mm screws at the top on each side.
    • Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
    • You should now be able to push the back out with the four screws removed to see the light bulb.
  7. Cuisinart TOA-60FR Lightbulb Replacement: adım 7, 1 resimden 1.
    • Remove these four screws.
    • Pull the light away from it's window.
  8. Cuisinart TOA-60FR Lightbulb Replacement: adım 8, 2 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement: adım 8, 2 resimden 2.
    • Using a wrench, remove the washer.
    • Pull the silver casing off the lightbulb.
  9. Cuisinart TOA-60FR Lightbulb Replacement: adım 9, 2 resimden 1. Cuisinart TOA-60FR Lightbulb Replacement: adım 9, 2 resimden 2.
    • Now unscrew the lightbulb to replace it with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 56
Her zaman: 556
