Giriş
Are you having trouble with a flickering light bulb in your Cuisinart TOA-60FR? If so, this guide will help you know if you need to replace your lightbulb or find other solutions.
Make sure you set aside a fair amount of time to complete this; even if you replace your lightbulb, it isn't easy without removing the whole outside of the device. The lightbulb illuminates the entire toaster oven; it may appear insignificant, but it is an essential component.
Neye ihtiyacın var
Remove these two 12.8 mm screws at the top on each side.
Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
