Ana içeriğe geç
Cuisinart TOA-60FR Power Cord Replacement
Neye ihtiyacın var
  1. Cuisinart TOA-60FR Power Cord Replacement, Outside removal: adım 1, 1 resimden 1.
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Power Cord Replacement: adım 2, 2 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Power Cord Replacement: adım 3, 3 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 3, 3 resimden 2. Cuisinart TOA-60FR Power Cord Replacement: adım 3, 3 resimden 3.
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Power Cord Replacement: adım 4, 2 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 4, 2 resimden 2.
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Power Cord Replacement: adım 5, 3 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 5, 3 resimden 2. Cuisinart TOA-60FR Power Cord Replacement: adım 5, 3 resimden 3.
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Power Cord Replacement, Power Cord: adım 6, 1 resimden 1.
    • Take the needle nose pliers and cut off the crimped-on-wire connectors.
    • Pressed down hard. These wires are thick.
    • These are crimped on wire conncetors so they can not be twisted off. The only way to remove them is by cutting off the wire.
  7. Cuisinart TOA-60FR Power Cord Replacement: adım 7, 3 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 7, 3 resimden 2. Cuisinart TOA-60FR Power Cord Replacement: adım 7, 3 resimden 3.
    • Strip the wires back with wire strippers. Or carefully take the needle nose pliers and cut gently to only make a mark on the jacket and not the wires. Then pull with the pliers to remove the jacket.
  8. Cuisinart TOA-60FR Power Cord Replacement: adım 8, 3 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 8, 3 resimden 2. Cuisinart TOA-60FR Power Cord Replacement: adım 8, 3 resimden 3.
    • Take the white, blue, and black wire together and push togther
    • Then take the pliers and twist them until they are all combined.
  9. Cuisinart TOA-60FR Power Cord Replacement: adım 9, 2 resimden 1. Cuisinart TOA-60FR Power Cord Replacement: adım 9, 2 resimden 2.
    • Crimp the wire connector with a crimper or pliers
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 127
