Giriş
Removing the back panel requires taking of the top panel first. Then, you must remove four more screws on the back.
Neye ihtiyacın var
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Bir başkası bu kılavuzu tamamladı.
