Ana içeriğe geç
CyberHome CH-DVD 300 Top Panel Replacement
Neye ihtiyacın var
  1. CyberHome CH-DVD 300 Top Panel Replacement, Top Panel: adım 1, 2 resimden 1. CyberHome CH-DVD 300 Top Panel Replacement, Top Panel: adım 1, 2 resimden 2.
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Top Panel Replacement: adım 2, 2 resimden 1. CyberHome CH-DVD 300 Top Panel Replacement: adım 2, 2 resimden 2.
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Menezes
642 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-5, Forte Spring 2014 Cal Poly, Team 6-5, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G5
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 519
