Ana içeriğe geç
CyberPowerPC RGB 7 Color USB Outlet Replacement
Neye ihtiyacın var
    1. CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: adım 1, 2 resimden 1. CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: adım 1, 2 resimden 2.
      • Be sure to unplug the keyboard before starting the disassembly.
      • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
      FixBot'a Sor
      Yorum Ekle
    2. CyberPowerPC RGB 7 Color USB Outlet Replacement: adım 2, 2 resimden 1. CyberPowerPC RGB 7 Color USB Outlet Replacement: adım 2, 2 resimden 2.
      • Remove the sixteen 5 mm length screws using the Phillips head #2.
      • One of the screws may be located underneath a manufacturer's sticker.
      FixBot'a Sor
      Yorum Ekle
    3. CyberPowerPC RGB 7 Color USB Outlet Replacement: adım 3, 1 resimden 1.
      • Lift up and remove the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    1. CyberPowerPC RGB 7 Color USB Outlet Replacement, LED Backlight: adım 4, 1 resimden 1.
      • Remove the metal backing located directly underneath the white plastic casing.
      FixBot'a Sor
      Yorum Ekle
    2. CyberPowerPC RGB 7 Color USB Outlet Replacement: adım 5, 1 resimden 1.
      • Be careful not to pull too hard on the ribbon cable, as it may break.
      • Disconnect the ribbon cable that connects the LED board to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. CyberPowerPC RGB 7 Color USB Outlet Replacement: adım 6, 1 resimden 1.
      • Carefully remove the LED board, which should now come free from the casing.
      FixBot'a Sor
      Yorum Ekle
    1. CyberPowerPC RGB 7 Color USB Outlet Replacement, USB Outlet: adım 7, 1 resimden 1.
      • Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ekip
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S15G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 1,315
