Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the sixteen 5 mm length screws using the Phillips head #2.
One of the screws may be located underneath a manufacturer's sticker.
Remove the metal backing located directly underneath the white plastic casing.
Disconnect the ribbon cable that connects the LED board to the motherboard.
Carefully remove the LED board, which should now come free from the casing.
Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
