Ana içeriğe geç
CyberSeriesPC C-Series RAM Replacement
Neye ihtiyacın var
  1. CyberSeriesPC C-Series RAM Replacement, RAM: adım 1, 3 resimden 1. CyberSeriesPC C-Series RAM Replacement, RAM: adım 1, 3 resimden 2. CyberSeriesPC C-Series RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Before doing anything, you must be sure that the computer itself is off so no damage or loss of data can be made to the computer.
    • Turn the computer around and turn the power switch from "I" (on) to "O" (off).
    • Remove the power cable from its outlet and disconnect any peripherals (microphone, webcam, etc.).
  2. CyberSeriesPC C-Series RAM Replacement: adım 2, 3 resimden 1. CyberSeriesPC C-Series RAM Replacement: adım 2, 3 resimden 2. CyberSeriesPC C-Series RAM Replacement: adım 2, 3 resimden 3.
    • Place the computer on a table.
    • Remove the screws holding the side panel with a screwdriver.
    • Slide the side panel from right to left to open the computer and see its components.
    • Place the side panel somewhere else to keep the area clear, and set the computer down on its side, where the open side is up for you to work.
    • From here on out, you should have your flashlight to shine a light on your computer so you can see the components.
  3. CyberSeriesPC C-Series RAM Replacement: adım 3, 3 resimden 1. CyberSeriesPC C-Series RAM Replacement: adım 3, 3 resimden 2. CyberSeriesPC C-Series RAM Replacement: adım 3, 3 resimden 3.
    • Open the latches in front of the RAM using two fingers.
    • Place two fingers and your thumb down in the middle of the RAM stick and remove it carefully and slowly.
    • Repeat this step for both RAM sticks.
  4. CyberSeriesPC C-Series RAM Replacement: adım 4, 3 resimden 1. CyberSeriesPC C-Series RAM Replacement: adım 4, 3 resimden 2. CyberSeriesPC C-Series RAM Replacement: adım 4, 3 resimden 3.
    • Line up the middle gap in the new RAM stick with the notch in the computer.
    • Push the stick down to insert the RAM into its place.
    • When properly inserted, you will hear a click and the latch will automatically close to hold the RAM stick in place.
    • Repeat this step for the second stick.
    • When inserting the RAM, do not push down too hard. Considering the sticks are fragile, too much force can break the RAM stick.
  5. CyberSeriesPC C-Series RAM Replacement: adım 5, 3 resimden 1. CyberSeriesPC C-Series RAM Replacement: adım 5, 3 resimden 2. CyberSeriesPC C-Series RAM Replacement: adım 5, 3 resimden 3.
    • Slide the side panel back onto the computer from the left until it clicks.
    • Tighten the screws back onto the side panel with the screwdriver.
    • Before reinserting the power cable and turning the power switch on, insert any other removed wires.
    • Place the power cable back in its outlet.
    • Turn the power switch on.
  6. CyberSeriesPC C-Series RAM Replacement: adım 6, 3 resimden 1. CyberSeriesPC C-Series RAM Replacement: adım 6, 3 resimden 2. CyberSeriesPC C-Series RAM Replacement: adım 6, 3 resimden 3.
    • To confirm the RAM sticks are properly working, turn the computer on and let it boot up.
    • Click on the search button in the lower-left corner of your monitor screen.
    • Search for "System Information," then click on it.
    • In the "Find what:" search bar, type "RAM," and press enter.
    • You will see that your new RAM is installed correctly and working, making it a successful switching of parts!
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jamie Lira
253 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 66
Her zaman: 3,009
