Ana içeriğe geç
Cyberpower Elite M1-131 Cord Replacement
Neye ihtiyacın var
  1. Cyberpower Elite M1-131 Cord Replacement, Cord: adım 1, 3 resimden 1. Cyberpower Elite M1-131 Cord Replacement, Cord: adım 1, 3 resimden 2. Cyberpower Elite M1-131 Cord Replacement, Cord: adım 1, 3 resimden 3.
    • Hold the mouse in a position where the feet are facing you.
    • With a plastic anti-static tweezer or a Spudger, take off the mouse feet carefully.
    • The feet will need to be reapplied during reassembly.
  2. Cyberpower Elite M1-131 Cord Replacement: adım 2, 2 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws on the back.
    • Do not remove the white part on the mouse feet. They are sticky and will help put your mouse feet back on.
  3. Cyberpower Elite M1-131 Cord Replacement: adım 3, 3 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 3, 3 resimden 2. Cyberpower Elite M1-131 Cord Replacement: adım 3, 3 resimden 3.
    • Gently put the mouse down with the sensor facing down and carefully pull the top shell from the mouse.
  4. Cyberpower Elite M1-131 Cord Replacement: adım 4, 3 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 4, 3 resimden 2. Cyberpower Elite M1-131 Cord Replacement: adım 4, 3 resimden 3.
    • Grasp the 5-pin plastic white pin connector from both sides and gently pull it up.
    • Do NOT pull on the wires.
  5. Cyberpower Elite M1-131 Cord Replacement: adım 5, 2 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 5, 2 resimden 2.
    • Unwrap the old cable, pull it out, and remove it from sight.
  6. Cyberpower Elite M1-131 Cord Replacement: adım 6, 3 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 6, 3 resimden 2. Cyberpower Elite M1-131 Cord Replacement: adım 6, 3 resimden 3.
    • With your new cable, place the 5-pin connector into the connector socket.
    • Do NOT push down on the wires.
    • Tuck in the cable.
    • Place the plastic cube in front of the mouse wheel. There will be a perfect fit for that cube to hold the cable in place.
  7. Cyberpower Elite M1-131 Cord Replacement: adım 7, 2 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 7, 2 resimden 2.
    • Place the top shell back on top of the mouse and press down until you hear a small click.
    • Lift the mouse so the sensor is facing you.
  8. Cyberpower Elite M1-131 Cord Replacement: adım 8, 2 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 8, 2 resimden 2.
    • Screw back in the four 2 mm screws that you removed earlier with your Phillips screwdriver.
  9. Cyberpower Elite M1-131 Cord Replacement: adım 9, 2 resimden 1. Cyberpower Elite M1-131 Cord Replacement: adım 9, 2 resimden 2.
    • Reapply the mouse feet that you carefully took off earlier.
    • You can also apply new ones if you have any.
Sonuç
Nathaniel A
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 285
