Ana içeriğe geç
CygoLite Night Rover Rubber Charging Input Gasket Replacement
Neye ihtiyacın var
  1. CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: adım 1, 3 resimden 1. CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: adım 1, 3 resimden 2. CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: adım 1, 3 resimden 3.
    • Place the CygoLite on a flat surface with the bottom side facing up.
    • Locate the four screws on the bottom of the device.
    • Unscrew them with a Phillips head screwdriver and remove the bottom casing.
  2. CygoLite Night Rover Rubber Charging Input Gasket Replacement: adım 2, 2 resimden 1. CygoLite Night Rover Rubber Charging Input Gasket Replacement: adım 2, 2 resimden 2.
    • Locate the rubber gasket on the side of the device.
    • Place your new replacement rubber gasket onto the side of the casing and gently place the top of the case back on top of it.
    • Be sure to line up the grooves in the casing with the grooves on the rubber gasket.
Sonuç
Trent Vigar
101 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2012 Clemson, Team 14-3, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 370
