Ana içeriğe geç
D-Link HD Wi-Fi Camera Motherboard Replacement
Neye ihtiyacın var
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: adım 2, 2 resimden 1. D-Link   HD Wi-Fi Camera Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: adım 3, 2 resimden 1. D-Link   HD Wi-Fi Camera Motherboard Replacement: adım 3, 2 resimden 2.
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
Sonuç
Morgen Jaques
533 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 819
