Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. Remove the back casing to expose the circuit board.
    • Remove the back casing to expose the circuit board.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  5. Detach the speaker wire by gently pulling on the side closest to the body of the camera.
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Collyn Dodge
305 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team S4-G2, Baechle Spring 2018 IUPUI, Team S4-G2, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S4G2
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 94
