Ana içeriğe geç
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
Neye ihtiyacın var
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: adım 1, 1 resimden 1.
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 3, 1 resimden 1.
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 4, 1 resimden 1.
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: adım 5, 1 resimden 1.
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 6, 2 resimden 1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 6, 2 resimden 2.
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 7, 2 resimden 1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 7, 2 resimden 2.
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 8, 2 resimden 1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 8, 2 resimden 2.
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 9, 3 resimden 1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 9, 3 resimden 2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: adım 9, 3 resimden 3.
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
Sonuç
Ekip
IUPUI, Team S4-G2, Baechle Spring 2018 IUPUI, Team S4-G2, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 369
