Ana içeriğe geç
D-Link DCS-2630L Wi-Fi Camera Speaker Replacement
Neye ihtiyacın var
  1. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement, Back casing: adım 1, 1 resimden 1.
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: adım 3, 1 resimden 1.
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: adım 4, 1 resimden 1.
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Remove the two 7.25 mm screws using the Ph00 head.
  6. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the back grey speaker plate
  7. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the speaker by gently pulling on the wire near the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Collyn Dodge
323 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G2, Baechle Spring 2018 IUPUI, Team S4-G2, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 276
