Ana içeriğe geç
D-Link DCS-5222L Lens Replacement
Neye ihtiyacın var
  1. D-Link DCS-5222L Lens Replacement, Lens: adım 1, 3 resimden 1. D-Link DCS-5222L Lens Replacement, Lens: adım 1, 3 resimden 2. D-Link DCS-5222L Lens Replacement, Lens: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the four rubber feet with tweezers to access the screws.
    • Remove all four 7mm screws by using a #1 Phillips screwdriver.
    • Then, with your hands, pull off the lower part of the camera body.
    FixBot'a Sor
  2. D-Link DCS-5222L Lens Replacement: adım 2, 3 resimden 1. D-Link DCS-5222L Lens Replacement: adım 2, 3 resimden 2. D-Link DCS-5222L Lens Replacement: adım 2, 3 resimden 3.
    • On the base motherboard, there are five connecting cables. Disconnect all of them from the motherboard gently using safety tweezers.
    • Do not cut or damage the cables.
    • Disconnecting the antenna cable from motherboard is not necessary.
    FixBot'a Sor
  3. D-Link DCS-5222L Lens Replacement: adım 3, 3 resimden 1. D-Link DCS-5222L Lens Replacement: adım 3, 3 resimden 2. D-Link DCS-5222L Lens Replacement: adım 3, 3 resimden 3.
    • Remove the two 7mm screws holding the motor using a #1 Phillips screwdriver.
    • Pull off the motor and lift away the midbody of the camera using your hands.
    FixBot'a Sor
  4. D-Link DCS-5222L Lens Replacement: adım 4, 2 resimden 1. D-Link DCS-5222L Lens Replacement: adım 4, 2 resimden 2.
    • Separate the black camera shroud from the upper body by prying loose the tabs with a plastic opening tool or spudger.
    • Use your hands to wiggle the shroud free.
    FixBot'a Sor
  5. D-Link DCS-5222L Lens Replacement: adım 5, 3 resimden 1. D-Link DCS-5222L Lens Replacement: adım 5, 3 resimden 2. D-Link DCS-5222L Lens Replacement: adım 5, 3 resimden 3.
    • Use a #1 Phillips screwdriver to unscrew the four 5mm screws on both sides of the black camera housing to separate it from white body.
    • Unscrew the two 7mm #1 Phillips screws on both sides of the camera housing to open it.
    FixBot'a Sor
  6. D-Link DCS-5222L Lens Replacement: adım 6, 3 resimden 1. D-Link DCS-5222L Lens Replacement: adım 6, 3 resimden 2. D-Link DCS-5222L Lens Replacement: adım 6, 3 resimden 3.
    • Gently disconnect the three cables from the small motherboard using safety tweezers.
    • Use a #0 Phillips screwdriver to remove the two black 2mm screws and a #1 Phillips screwdriver to remove the 2 silver 6mm screws.
    • Separate the board from the black housing.
    FixBot'a Sor
  7. D-Link DCS-5222L Lens Replacement: adım 7, 3 resimden 1. D-Link DCS-5222L Lens Replacement: adım 7, 3 resimden 2. D-Link DCS-5222L Lens Replacement: adım 7, 3 resimden 3.
    • Using your fingers, remove the focus adjustment ring.
    • Twist the lens to unscrew it from the camera module.
    • Replace the broken lens with new one and reassemble all parts of the camera respectively.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Atefeh Rahmani
172 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 64
Her zaman: 1,431
