Ana içeriğe geç
D-Link DCS-5222L Motherboard Replacement
Neye ihtiyacın var
  1. D-Link DCS-5222L Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. D-Link DCS-5222L Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L Motherboard Replacement: adım 3, 2 resimden 1. D-Link DCS-5222L Motherboard Replacement: adım 3, 2 resimden 2.
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L Motherboard Replacement: adım 4, 3 resimden 1. D-Link DCS-5222L Motherboard Replacement: adım 4, 3 resimden 2. D-Link DCS-5222L Motherboard Replacement: adım 4, 3 resimden 3.
    • Disconnect the five quick connections attaching the various cables to the motherboard with your fingers or blunt ended tweezers.
  5. D-Link DCS-5222L Motherboard Replacement: adım 5, 2 resimden 1. D-Link DCS-5222L Motherboard Replacement: adım 5, 2 resimden 2.
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  6. D-Link DCS-5222L Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a #1 Phillips screwdriver, remove the single 7mm screw holding the motherboard in place.
  7. D-Link DCS-5222L Motherboard Replacement: adım 7, 3 resimden 1. D-Link DCS-5222L Motherboard Replacement: adım 7, 3 resimden 2. D-Link DCS-5222L Motherboard Replacement: adım 7, 3 resimden 3.
    • Wiggle free the motherboard from the bottom of the body.
    • There are two pegs that limit the motherboard's rotation. Have some patience when wiggling it free.
    • The power and ethernet ports have ledges along their top surface. These must be removed from the body at an angle relative to the horizontal.
Sonuç
Ryan Null
377 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 1,099
