Ana içeriğe geç
D-Link DCS-5222L Motor Replacement
Neye ihtiyacın var
  1. D-Link DCS-5222L Motor Replacement, Motors: adım 1, 3 resimden 1. D-Link DCS-5222L Motor Replacement, Motors: adım 1, 3 resimden 2. D-Link DCS-5222L Motor Replacement, Motors: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the four rubber feet on the bottom of the camera with tweezers.
    • Remove the four screws using a Phillips #1 screwdriver.
    • Remove the lower piece of the camera body.
  2. D-Link DCS-5222L Motor Replacement: adım 2, 2 resimden 1. D-Link DCS-5222L Motor Replacement: adım 2, 2 resimden 2.
    • Remove the motherboard and bottom of the camera body.
    • Disconnect the five cables from the motherboard using tweezers.
  3. D-Link DCS-5222L Motor Replacement: adım 3, 2 resimden 1. D-Link DCS-5222L Motor Replacement: adım 3, 2 resimden 2.
    • Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place.
  4. D-Link DCS-5222L Motor Replacement: adım 4, 2 resimden 1. D-Link DCS-5222L Motor Replacement: adım 4, 2 resimden 2.
    • Using your hands, separate the bottom of the body from the upper portion.
  5. D-Link DCS-5222L Motor Replacement: adım 5, 2 resimden 1. D-Link DCS-5222L Motor Replacement: adım 5, 2 resimden 2.
    • To remove the top of the camera you must push in the black tabs using the spudger. There are 3 tabs per side.
    • While pushing in the tabs, you can now lift the top black portion of the camera using your hands.
  6. D-Link DCS-5222L Motor Replacement: adım 6, 2 resimden 1. D-Link DCS-5222L Motor Replacement: adım 6, 2 resimden 2.
    • With a little wiggle, the camera module will come free from the body.
    • Unscrew the two 7mm screws on the camera using a #1 Phillips screwdriver.
  7. D-Link DCS-5222L Motor Replacement: adım 7, 2 resimden 1. D-Link DCS-5222L Motor Replacement: adım 7, 2 resimden 2.
    • Pry apart the camera housing with your fingers to reveal the second motor.
  8. D-Link DCS-5222L Motor Replacement: adım 8, 1 resimden 1.
    • Unscrew the two 6mm screws holding the motor in place with a #1 Phillips screwdriver.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jason Munyon
268 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G5
3 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy new motor?
Michael Williams - Yanıt
I do not know, I purchased a “for Parts” camera on e-bay for $15.00 and used the motor from that unit.
Ed Wheelbarger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 938
