Giriş
If your camera is failing to move in a certain direction one of the two motors inside may be malfunctioning. If this is the case the motor will need to be replaced. The replacement process is pretty simple and doesn't need many tools. It is important to keep track of the small screws, they are easily lost.
Neye ihtiyacın var
Remove the four rubber feet on the bottom of the camera with tweezers.
Remove the four screws using a Phillips #1 screwdriver.
Remove the lower piece of the camera body.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Where can I buy new motor?
I do not know, I purchased a “for Parts” camera on e-bay for $15.00 and used the motor from that unit.
