Ana içeriğe geç
Giriş
If you find your camera is experiencing distorted audio it could be caused by a malfunctioning speaker. If this is the case the replacement of the speaker is a pretty simple and straightforward task. It is important that you keep track of the small screws, they are very easy to lose track of.
Parçalar
Hiçbir parça belirtilmedi.
  1. D-Link DCS-5222L Speaker Replacement, Speaker: adım 1, 3 resimden 1. D-Link DCS-5222L Speaker Replacement, Speaker: adım 1, 3 resimden 2. D-Link DCS-5222L Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the four rubber pieces to gain access to the screws.
    • Remove the four 7mm screws with a #1 Phillips screwdriver.
    • Remove the bottom of the camera body.
  2. D-Link DCS-5222L Speaker Replacement: adım 2, 2 resimden 1. D-Link DCS-5222L Speaker Replacement: adım 2, 2 resimden 2.
    • Using safety tweezers, disconnect the 2-wire connector with the red and black leads located close to the ethernet and SD ports.
    • Disconnect the cables gently.
  3. D-Link DCS-5222L Speaker Replacement: adım 3, 2 resimden 1. D-Link DCS-5222L Speaker Replacement: adım 3, 2 resimden 2.
    • The speaker is circular, black and silver in color with a red and black cord. It is easily removed from the upper body of the camera with your fingers or safety tweezers.
Sonuç
Jason Munyon
268 İtibar
2 adet Kılavuz yazıldı
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 200
