Ana içeriğe geç
D-Link DCS-825L Back Casing Replacement
Neye ihtiyacın var
  1. D-Link DCS-825L Back Casing Replacement, Accent Ring: adım 1, 1 resimden 1.
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L Back Casing Replacement: adım 2, 1 resimden 1.
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L Back Casing Replacement: adım 3, 1 resimden 1.
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L Back Casing Replacement, Back Casing: adım 4, 2 resimden 1. D-Link DCS-825L Back Casing Replacement, Back Casing: adım 4, 2 resimden 2.
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L Back Casing Replacement: adım 5, 3 resimden 1. D-Link DCS-825L Back Casing Replacement: adım 5, 3 resimden 2. D-Link DCS-825L Back Casing Replacement: adım 5, 3 resimden 3.
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L Back Casing Replacement: adım 6, 2 resimden 1. D-Link DCS-825L Back Casing Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L Back Casing Replacement: adım 7, 3 resimden 1. D-Link DCS-825L Back Casing Replacement: adım 7, 3 resimden 2. D-Link DCS-825L Back Casing Replacement: adım 7, 3 resimden 3.
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
Sonuç
April Ulrich
205 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Fall 2018 USF Tampa, Team S1-G5, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 390
