Ana içeriğe geç
D-Link DIR-890L Motherboard Replacement
Neye ihtiyacın var
    1. D-Link DIR-890L Motherboard  Replacement, Case: adım 1, 3 resimden 1. D-Link DIR-890L Motherboard  Replacement, Case: adım 1, 3 resimden 2. D-Link DIR-890L Motherboard  Replacement, Case: adım 1, 3 resimden 3.
      • Peel off the four rubber rectangular feet with your fingers.
      • The feet may be hard to remove. Apply additional force if necessary.
      FixBot'a Sor
      Yorum Ekle
    2. D-Link DIR-890L Motherboard  Replacement: adım 2, 3 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 2, 3 resimden 2. D-Link DIR-890L Motherboard  Replacement: adım 2, 3 resimden 3.
      • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. D-Link DIR-890L Motherboard  Replacement: adım 3, 3 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 3, 3 resimden 2. D-Link DIR-890L Motherboard  Replacement: adım 3, 3 resimden 3.
      • Wedge the opening tool between the red top panel and the gray bottom panel.
      • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
      FixBot'a Sor
      Yorum Ekle
    1. D-Link DIR-890L Motherboard  Replacement, Motherboard: adım 4, 1 resimden 1.
      • Orient the router so the narrow end of the router faces you and the ports face away from you.
      • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. D-Link DIR-890L Motherboard  Replacement: adım 5, 3 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 5, 3 resimden 2. D-Link DIR-890L Motherboard  Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      Heavy-Duty Spudger
      FixBot'a Sor
      Yorum Ekle
    3. D-Link DIR-890L Motherboard  Replacement: adım 6, 2 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 6, 2 resimden 2.
      • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. D-Link DIR-890L Motherboard  Replacement: adım 7, 3 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 7, 3 resimden 2. D-Link DIR-890L Motherboard  Replacement: adım 7, 3 resimden 3.
      • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
      FixBot'a Sor
      Yorum Ekle
    5. D-Link DIR-890L Motherboard  Replacement: adım 8, 3 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 8, 3 resimden 2. D-Link DIR-890L Motherboard  Replacement: adım 8, 3 resimden 3.
      • Pull the yellow tape off of the motherboard to release the final antenna wire.
      FixBot'a Sor
      Yorum Ekle
    6. D-Link DIR-890L Motherboard  Replacement: adım 9, 2 resimden 1. D-Link DIR-890L Motherboard  Replacement: adım 9, 2 resimden 2.
      • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rachel Shaw
553 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Livingston Fall 2016 Cal Poly, Team 10-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G7
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 2,748
