Ana içeriğe geç
D-Link EBR-2310 LED Light Replacement
Neye ihtiyacın var
    1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: adım 1, 1 resimden 1.
      • Begin by placing the wired router face down.
      • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
      • The two bottom plastic screw coverings do not need to be taken off.
      FixBot'a Sor
      Yorum Ekle
    2. D-Link EBR-2310 LED Light Replacement, Remove Screws: adım 2, 1 resimden 1.
      • Using a Phillips #2 screwdriver, remove the two top screws.
      FixBot'a Sor
      Yorum Ekle
    3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: adım 3, 1 resimden 1.
      • Use a plastic opening tool between the edges of the router and gently pry the device apart.
      • Release the clips as you work your way around the device to avoid breaking them.
      • Separate the front and back case of the router.
      FixBot'a Sor
      Yorum Ekle
    4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: adım 4, 2 resimden 1. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: adım 4, 2 resimden 2.
      • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
      • It should easily snap out of place.
      FixBot'a Sor
      Yorum Ekle
    5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: adım 5, 2 resimden 1. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: adım 5, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: adım 6, 1 resimden 1.
      • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
      • You have now removed the logic board from your device.
      FixBot'a Sor
      Yorum Ekle
    1. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: adım 7, 1 resimden 1.
      • Locate the problematic LED light on the motherboard.
      • Using a plastic opening tool, very gently tilt its black base backwards.
      FixBot'a Sor
      Yorum Ekle
    2. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: adım 8, 2 resimden 1. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: adım 8, 2 resimden 2.
      • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
      FixBot'a Sor
      Yorum Ekle
    3. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: adım 9, 1 resimden 1.
      Bu adımda kullanılan alet:
      • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
      FixBot'a Sor
      Yorum Ekle
    4. D-Link EBR-2310 LED Light Replacement, Complete Removal: adım 10, 1 resimden 1.
      • You should now have a removed LED light, ready to be replaced with a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jessica
428 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 707
