Ana içeriğe geç
D-Link EBR-2310 Motherboard Replacement
Neye ihtiyacın var
  1. D-Link EBR-2310 Motherboard Replacement, Remove Plastic Screw Coverings: adım 1, 1 resimden 1.
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 Motherboard Replacement, Remove Screws: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 Motherboard Replacement, Pry Open The Router: adım 3, 1 resimden 1.
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: adım 4, 2 resimden 1. D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: adım 4, 2 resimden 2.
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: adım 5, 2 resimden 1. D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: adım 5, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 Motherboard Replacement, Remove Bottom Case: adım 6, 1 resimden 1.
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessica
428 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 871
