Ana içeriğe geç
D-Link EBR-2310 disassembly for cleaning
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. D-Link EBR-2310 disassembly for cleaning, Remove Plastic Screw Coverings: adım 1, 1 resimden 1.
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 disassembly for cleaning, Remove Screws: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 disassembly for cleaning, Pry Open The Router: adım 3, 1 resimden 1.
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 disassembly for cleaning, Remove Silver Casing: adım 4, 2 resimden 1. D-Link EBR-2310 disassembly for cleaning, Remove Silver Casing: adım 4, 2 resimden 2.
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 disassembly for cleaning, Remove Inner Bottom Screws: adım 5, 2 resimden 1. D-Link EBR-2310 disassembly for cleaning, Remove Inner Bottom Screws: adım 5, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 disassembly for cleaning, Remove Bottom Case: adım 6, 1 resimden 1.
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
  7. D-Link EBR-2310 disassembly for cleaning, Remove Dust Particles: adım 7, 1 resimden 1.
    • Once you have completely removed your logic board from its casing, look for any large dust particles and/or other dirt inside the router. Gently remove these particles with your fingers.
  8. D-Link EBR-2310 disassembly for cleaning, Maintain Blue Rubber Coverings: adım 8, 1 resimden 1.
    • Locate the blue rubber wire coverings near the main cable connections of your motherboard. Make sure that these are standing upright.
    • If they are not, gently use your wire tweezers to rearrange them in the correct upright position.
  9. D-Link EBR-2310 disassembly for cleaning, Wire Tube: adım 9, 2 resimden 1. D-Link EBR-2310 disassembly for cleaning, Wire Tube: adım 9, 2 resimden 2.
    • Locate the upright wire tube towards the middle left of the motherboard.
    • Make sure that the wires are evenly spaced, not directly touching one another on the tube.
    • If the wires are not evenly spaced, gently use your spudger tool to separate them.
  10. D-Link EBR-2310 disassembly for cleaning, Wipe The Top Side of the Logic Board: adım 10, 1 resimden 1.
    • Using a soft cloth, gently wipe the top side of the motherboard.
    • Be sure not to miss any small crevices.
  11. D-Link EBR-2310 disassembly for cleaning, Wipe Dust From Metal Slates: adım 11, 1 resimden 1.
    • Using your cloth, gently wipe the metal slates around the cable connectors.
  12. D-Link EBR-2310 disassembly for cleaning, Wipe The Back Side of the Logic Board: adım 12, 1 resimden 1.
    • Turn the motherboard on its back side and completely wipe away any small particles.
  13. D-Link EBR-2310 disassembly for cleaning, Wipe The Outer Cases: adım 13, 1 resimden 1.
    • Fully wipe the top and bottom cases of the router.
    • Dust easily gets stuck in these areas, especially the bottom case.
  14. D-Link EBR-2310 disassembly for cleaning, Wiping The Cable Compartments: adım 14, 1 resimden 1.
    • Wipe the cable connector compartments using the same soft cloth.
  15. D-Link EBR-2310 disassembly for cleaning, Deep Cleaning of Cable Compartments: adım 15, 1 resimden 1.
    • Using a soft bristle toothbrush, brush the insides of the cable connectors in order to remove any hard-to-reach dust.
  16. D-Link EBR-2310 disassembly for cleaning, Brush the Logic Board: adım 16, 1 resimden 1.
    • Using the same toothbrush, brush the tiny crevices on the back side of the motherboard.
  17. D-Link EBR-2310 disassembly for cleaning, Continue Brushing the Logic Board: adım 17, 1 resimden 1.
    • After you have thoroughly brushed the back side of the motherboard, begin to do the same with the front side.
    • You have now cleaned the inside of your router. Ventilation and performance should be excellent.
Sonuç
Jessica
428 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 272
