Ana içeriğe geç
D-Link HD Wi-Fi Camera Camera Lens Replacement
Neye ihtiyacın var
  1. D-Link HD Wi-Fi Camera Camera Lens Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Camera Lens Replacement: adım 2, 2 resimden 1. D-Link HD Wi-Fi Camera Camera Lens Replacement: adım 2, 2 resimden 2.
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
    After removing the screws, there are 4 tabs holding the back cover on. Each tab is located at the edge of a vent. Pry at each point to remove the back cover. Take care not to damage the Micro SD card holder.
    Forrest - Yanıt
  3. D-Link HD Wi-Fi Camera Camera Lens Replacement: adım 3, 2 resimden 1. D-Link HD Wi-Fi Camera Camera Lens Replacement: adım 3, 2 resimden 2.
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: adım 4, 2 resimden 1. D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: adım 4, 2 resimden 2.
    • Make sure your hands are dry and you are working in a dry area. To prevent damage, do not touch the lens.
    • There are two Phillips #00 6.0mm screws keeping the camera in place. Remove the screws first.
    • Gently unplug the camera from the motherboard, and remove the camera.
Sonuç
Morgen Jaques
557 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
How do I get hold of a replacement lens? Can’t seem to find anyone selling them. Need one for a DCS-2670L
Paul Williams - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,257
