Ana içeriğe geç
D-Link HD Wi-Fi Camera LED Lights Replacement
Neye ihtiyacın var
  1. D-Link HD Wi-Fi Camera LED Lights Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera LED Lights Replacement: adım 2, 2 resimden 1. D-Link HD Wi-Fi Camera LED Lights Replacement: adım 2, 2 resimden 2.
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera LED Lights Replacement: adım 3, 2 resimden 1. D-Link HD Wi-Fi Camera LED Lights Replacement: adım 3, 2 resimden 2.
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera LED Lights Replacement, Microphone: adım 4, 1 resimden 1.
    • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
  5. D-Link HD Wi-Fi Camera LED Lights Replacement: adım 5, 2 resimden 1. D-Link HD Wi-Fi Camera LED Lights Replacement: adım 5, 2 resimden 2.
    • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
  6. D-Link HD Wi-Fi Camera LED Lights Replacement, LED Lights: adım 6, 1 resimden 1.
    • There are two lights, one on either side of the board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Morgen Jaques
557 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 493
