Ana içeriğe geç
D-Link dir-645 Disassembly
Neye ihtiyacın var
  1. D-Link dir-645 Disassembly, Pry off the top: adım 1, 1 resimden 1.
    • Pry off the top using a plastic pryer
  2. D-Link dir-645 Disassembly, Unscrew the bottom screws: adım 2, 1 resimden 1.
    • Bottom: unscrew the two philips screws . Note: this probably voids any warranty
  3. D-Link dir-645 Disassembly, Pry off the bottom: adım 3, 1 resimden 1.
    • Carefully pry off the bottom plastic
  4. D-Link dir-645 Disassembly, Split the cylinder in half: adım 4, 2 resimden 1. D-Link dir-645 Disassembly, Split the cylinder in half: adım 4, 2 resimden 2.
    • Start to pry at the bottom.
    • Work your way around until it comes off.
  5. D-Link dir-645 Disassembly, Opened!: adım 5, 2 resimden 1. D-Link dir-645 Disassembly, Opened!: adım 5, 2 resimden 2.
    • The inside consists of the main board ant the antenna, that's it.
    • The 360 deg antenna is connected to the main board with Hirose U.FL connectors and can be easily removed. https://en.wikipedia.org/wiki/Hirose_U.F...
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Endorph
2.385 İtibar
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 521
