Ana içeriğe geç
DBPOWER RD-810 Magnifier Replacement
Neye ihtiyacın var
  1. DBPOWER RD-810 Magnifier Replacement, Top Cover: adım 1, 2 resimden 1. DBPOWER RD-810 Magnifier Replacement, Top Cover: adım 1, 2 resimden 2.
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Magnifier Replacement: adım 2, 1 resimden 1.
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Magnifier Replacement, Motherboard and LED Bulb: adım 3, 3 resimden 1. DBPOWER RD-810 Magnifier Replacement, Motherboard and LED Bulb: adım 3, 3 resimden 2. DBPOWER RD-810 Magnifier Replacement, Motherboard and LED Bulb: adım 3, 3 resimden 3.
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Magnifier Replacement: adım 4, 3 resimden 1. DBPOWER RD-810 Magnifier Replacement: adım 4, 3 resimden 2. DBPOWER RD-810 Magnifier Replacement: adım 4, 3 resimden 3.
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Magnifier Replacement: adım 5, 3 resimden 1. DBPOWER RD-810 Magnifier Replacement: adım 5, 3 resimden 2. DBPOWER RD-810 Magnifier Replacement: adım 5, 3 resimden 3.
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Magnifier Replacement, Magnifier: adım 6, 3 resimden 1. DBPOWER RD-810 Magnifier Replacement, Magnifier: adım 6, 3 resimden 2. DBPOWER RD-810 Magnifier Replacement, Magnifier: adım 6, 3 resimden 3.
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the Magnifier out of the projector.
Sonuç
John Russell
941 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 308
