Ana içeriğe geç
DBPOWER RD-810 Power Supply Switch Replacement
Neye ihtiyacın var
  1. DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: adım 1, 2 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: adım 1, 2 resimden 2.
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Power Supply Switch Replacement: adım 2, 1 resimden 1.
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: adım 3, 3 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: adım 3, 3 resimden 2. DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: adım 3, 3 resimden 3.
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Power Supply Switch Replacement: adım 4, 3 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement: adım 4, 3 resimden 2. DBPOWER RD-810 Power Supply Switch Replacement: adım 4, 3 resimden 3.
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Power Supply Switch Replacement: adım 5, 3 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement: adım 5, 3 resimden 2. DBPOWER RD-810 Power Supply Switch Replacement: adım 5, 3 resimden 3.
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: adım 6, 3 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: adım 6, 3 resimden 2. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: adım 6, 3 resimden 3.
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Power Supply Switch Replacement: adım 7, 2 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement: adım 7, 2 resimden 2.
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: adım 8, 3 resimden 1. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: adım 8, 3 resimden 2. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: adım 8, 3 resimden 3.
    • Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case.
Sonuç
John Russell
914 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 191
