Ana içeriğe geç
DBPOWER T20 Disassembly
Neye ihtiyacın var
  1. DBPOWER T20 Disassembly, DBPOWER T20 Disassembly: adım 1, 1 resimden 1.
    • Flip the device and lay flat.
  2. DBPOWER T20 Disassembly: adım 2, 1 resimden 1.
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Disassembly: adım 3, 3 resimden 1. DBPOWER T20 Disassembly: adım 3, 3 resimden 2. DBPOWER T20 Disassembly: adım 3, 3 resimden 3.
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Disassembly: adım 4, 1 resimden 1.
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Disassembly: adım 5, 2 resimden 1. DBPOWER T20 Disassembly: adım 5, 2 resimden 2.
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Disassembly: adım 6, 3 resimden 1. DBPOWER T20 Disassembly: adım 6, 3 resimden 2. DBPOWER T20 Disassembly: adım 6, 3 resimden 3.
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Disassembly: adım 7, 2 resimden 1. DBPOWER T20 Disassembly: adım 7, 2 resimden 2.
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Disassembly: adım 8, 1 resimden 1.
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Disassembly: adım 9, 2 resimden 1. DBPOWER T20 Disassembly: adım 9, 2 resimden 2.
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Disassembly: adım 10, 2 resimden 1. DBPOWER T20 Disassembly: adım 10, 2 resimden 2.
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrea Espinosa
521 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G2
5 Üyeler
5 adet Kılavuz yazıldı
4Kılavuz Yorumları
Anyone find a bulb for this thing? And/or know what else (or a quick fix) would fix a dark or burn mark on the image?
jcr4130 - Yanıt
haing the same issue tried to call a electronics repair place to see if the could order a new polarizing lens for me and they said they could not unless they were the ones that did the repair
derek_russell82308 -
Really? Well, crap
KweenBeeTX -
How are the lenses supposed to sit in the hompow t20 mini projector
Joseph Duffey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 3,243
