Ana içeriğe geç
DBPOWER T20 Lamp Replacement
Neye ihtiyacın var
  1. DBPOWER T20 Lamp Replacement, DBPOWER T20 Disassembly: adım 1, 1 resimden 1.
    • Flip the device and lay flat.
  2. DBPOWER T20 Lamp Replacement: adım 2, 1 resimden 1.
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lamp Replacement: adım 3, 3 resimden 1. DBPOWER T20 Lamp Replacement: adım 3, 3 resimden 2. DBPOWER T20 Lamp Replacement: adım 3, 3 resimden 3.
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lamp Replacement: adım 4, 1 resimden 1.
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lamp Replacement: adım 5, 2 resimden 1. DBPOWER T20 Lamp Replacement: adım 5, 2 resimden 2.
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lamp Replacement: adım 6, 3 resimden 1. DBPOWER T20 Lamp Replacement: adım 6, 3 resimden 2. DBPOWER T20 Lamp Replacement: adım 6, 3 resimden 3.
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lamp Replacement: adım 7, 2 resimden 1. DBPOWER T20 Lamp Replacement: adım 7, 2 resimden 2.
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lamp Replacement: adım 8, 1 resimden 1.
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lamp Replacement: adım 9, 2 resimden 1. DBPOWER T20 Lamp Replacement: adım 9, 2 resimden 2.
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lamp Replacement: adım 10, 2 resimden 1. DBPOWER T20 Lamp Replacement: adım 10, 2 resimden 2.
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lamp Replacement, Lamp: adım 11, 1 resimden 1.
    • Remove the two screws attached to the lamp with a J0 screwdriver.
  12. DBPOWER T20 Lamp Replacement: adım 12, 1 resimden 1.
    • Lift upwards to remove the lamp.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrea Espinosa
521 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G2
5 Üyeler
5 adet Kılavuz yazıldı
6Kılavuz Yorumları
where can I get the replacement lamp?
David Rug - Yanıt
The part that is being removed is NOT the LED lamp. My interest is replacing the actual LED lamp that sits behind the plastic part that is being removed. My projector image started to have a tan cast to it near the top left portion of the screen due to overheating. I am just assuming that it is the actual LED that is overheating and need replacing. The article is very good otherwise. Please add where replacement parts can be obtained.
m patn - Yanıt
Thank you very much, I appreciate the ability to get a look without having to open it up
Luke e Savage - Yanıt
Where can i buy the lamp?
Keshawn Buckner - Yanıt
Merci pour ce tuto! =) ça ma permis de nettoyer la lentille qui était pleine de poussière!
Jules Schminke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 17
Son 30 gün: 57
Her zaman: 4,376
