Ana içeriğe geç
DBPOWER T20 Lens Replacement
Neye ihtiyacın var
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: adım 1, 1 resimden 1.
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: adım 2, 1 resimden 1.
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: adım 3, 3 resimden 1. DBPOWER T20 Lens Replacement: adım 3, 3 resimden 2. DBPOWER T20 Lens Replacement: adım 3, 3 resimden 3.
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: adım 4, 1 resimden 1.
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: adım 5, 2 resimden 1. DBPOWER T20 Lens Replacement: adım 5, 2 resimden 2.
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: adım 6, 3 resimden 1. DBPOWER T20 Lens Replacement: adım 6, 3 resimden 2. DBPOWER T20 Lens Replacement: adım 6, 3 resimden 3.
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: adım 7, 2 resimden 1. DBPOWER T20 Lens Replacement: adım 7, 2 resimden 2.
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: adım 8, 1 resimden 1.
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: adım 9, 2 resimden 1. DBPOWER T20 Lens Replacement: adım 9, 2 resimden 2.
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: adım 10, 2 resimden 1. DBPOWER T20 Lens Replacement: adım 10, 2 resimden 2.
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: adım 11, 1 resimden 1.
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: adım 12, 1 resimden 1.
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: adım 13, 1 resimden 1.
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: adım 14, 2 resimden 1. DBPOWER T20 Lens Replacement: adım 14, 2 resimden 2.
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: adım 15, 1 resimden 1.
    • Remove the focus-adjustment ring from the lens housing.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrea Espinosa
521 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G2
5 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
How does the lens parts go together?
Lay - Yanıt
I need to know the same
Tremaine Mullins - Yanıt
Trying to put my lens back how to install
David Williams - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 2,695
