Giriş
You will not be able to access the lens without following these steps. Removing the lens does not take a lot of force since it is on a hinge and should lift out easily. However, none of the items you come in contact with leading up to the lens removal are sturdy so don't be afraid to use some force.
Neye ihtiyacın var
Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
Remove the focus-adjustment ring from the lens housing.
How do we replace the lens? I replaced my lens and it hasnt been clear ever since.. Too much blurr
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I need to know the same
Trying to put my lens back how to install
