Ana içeriğe geç
DDX/ Copperhead Hotend Installation
  1. DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: adım 1, 3 resimden 1. DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: adım 1, 3 resimden 2. DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: adım 1, 3 resimden 3.
    • Use 2x 2.5x6mm screws supplied with the Copperhead™ hotend.
    • Insert them in the mounting holes.
  2. DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: adım 2, 2 resimden 1. DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: adım 2, 2 resimden 2.
    • Attach Adapter and hotend.
    • New lineNotice the orientation of the Adapter and Hot Block.
    • These indented marks should be oriented towards the front of the DDX.
    • The fixation screws that attach the DDX to the carriage plate will enter through them.
  3. DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: adım 3, 3 resimden 1. DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: adım 3, 3 resimden 2. DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: adım 3, 3 resimden 3.
    • Insert the Capricorn tube inside the Adapter and hotend.
    • Push hard until it hits the bottom.
    • Download the PTFE cutting fixture
  4. DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: adım 4, 3 resimden 1. DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: adım 4, 3 resimden 2. DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: adım 4, 3 resimden 3.
    • Insert the Capricorn tube in the cutting fixture
    • Drive it until it fits the Adapter
    • Pressing all together use the hobby knife to cut the tube straight.
    • At the end, the Capricorn should stand out about 5mm.
  5. DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: adım 5, 3 resimden 1. DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: adım 5, 3 resimden 2. DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: adım 5, 3 resimden 3.
    • Spread the housing apart from 2 to 3mm
    • Insert the Copperhead™ in at an angle.
    • Push it until the mounting holes align.
  6. DDX/ Copperhead Hotend Installation, Close DDX 1/2: adım 6, 3 resimden 1. DDX/ Copperhead Hotend Installation, Close DDX 1/2: adım 6, 3 resimden 2. DDX/ Copperhead Hotend Installation, Close DDX 1/2: adım 6, 3 resimden 3.
    • If when clamping the DDX the gears collide:
    • Release the thumbscrew.
    • Open the hinge.
    • Clamp both halves while rotating the main gear back and forth.
  7. DDX/ Copperhead Hotend Installation, Close DDX 2/2: adım 7, 3 resimden 1. DDX/ Copperhead Hotend Installation, Close DDX 2/2: adım 7, 3 resimden 2. DDX/ Copperhead Hotend Installation, Close DDX 2/2: adım 7, 3 resimden 3.
    • When the DDX closes down verify the mounting holes alignment.
    • Screw the back screws to close it.
Sonuç
Tiny Machines 3D
3.019 İtibar
14 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
2Kılavuz Yorumları
where do i get the cutting fixture
Sarbartha Sengupta - Yanıt
Thanks for your questions. We’ve added a link to step 3.
Tiny Machines 3D -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 164
