Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. DJI Mavic 3 Pro cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. DJI Mavic 3 Pro Chip ID, Drone Main Board Side A: adım 1, 2 resimden 1. DJI Mavic 3 Pro Chip ID, Drone Main Board Side A: adım 1, 2 resimden 2.
    • Likely Leadcore H6MN applications processor
    • Likely Leadcore E2B video processor
    • Likely Leadcore P1 applications & baseband processor
    • SK Hynix H9HCNNNBKMMLXR-NEE 2 GB LPDDR4X SDRAM memory
    • SK Hynix H54G38AYRBX259 1 GB LPDDR4 SDRAM memory
    • Texas Instruments BQ24179 buck-boost battery charger
    • Richtek RT1715 USB Type-C power delivery controller
  2. DJI Mavic 3 Pro Chip ID: adım 2, 1 resimden 1.
    • Texas Instruments CDCI6214 four-output clock generator
    • Texas Instruments LP8758A2 power management
    • Texas Instruments LM61460AANRJRR 6 A step-down converter
    • SG Micro SGM61030A 3 A synchronous buck converter
    • Silergy SY8089A1 2 A synchronous step-down converter
    • Silicon Content Technology SCT2401FTVBR 600 mA synchronous step-down DC-DC converter
    • SG Micro SGM3157 SPDT analog switch
  3. DJI Mavic 3 Pro Chip ID, Drone Main Board Side A - Radio: adım 3, 1 resimden 1.
    • Likely Maxscend RF LNAs
  4. DJI Mavic 3 Pro Chip ID, Drone Main Board Side B: adım 4, 2 resimden 1. DJI Mavic 3 Pro Chip ID, Drone Main Board Side B: adım 4, 2 resimden 2.
  5. DJI Mavic 3 Pro Chip ID: adım 5, 1 resimden 1.
    • Texas Instruments CDC3RL02 dual channel clock buffer
    • DIOO DIO3340QN18 USB SuperSpeed 11 Gbps analog switch
    • Richtek RT5715 2 A synchronous step-down converter
    • Silergy SY6287CDEC power distribution switch
    • SG Micro SGM2566A 6 A load switch
  6. DJI Mavic 3 Pro Chip ID: adım 6, 1 resimden 1.
    • Joulwatt ideal diode controller (likely)
    • 3Peak TP181A1-CR bidirectional current sense amplifier
  7. DJI Mavic 3 Pro Chip ID, Drone Main Board Side B - Radio: adım 7, 1 resimden 1.
    • Likely Leadcore IE1000 RF transceiver
    • Skyworks SKY85743-21 5 GHz WLAN front-end module
    • Skyworks SKY85331-11 2.4 GHz WLAN front-end module
  8. DJI Mavic 3 Pro Chip ID, Bluetooth/WiFi Board: adım 8, 2 resimden 1. DJI Mavic 3 Pro Chip ID, Bluetooth/WiFi Board: adım 8, 2 resimden 2.
    • Synaptics SYN43752A2XKUBG single-chip WiFi 802.11ax w/ Bluetooth 5.1 & FM receiver
    • Likely Maxscend MXD8730 SP3T RF switch
    • Likely Maxscend MXD8622E SPDT RF switch
  9. DJI Mavic 3 Pro Chip ID, Camera Board: adım 9, 2 resimden 1. DJI Mavic 3 Pro Chip ID, Camera Board: adım 9, 2 resimden 2.
    • TDK-InvenSense ICM-40609-D 6-axis MEMS accelerometer & gyroscope
    • SG Micro SGM3204 200 mA charge pump voltage inverter
    • SG Micro SGM2209-ADJ - 500 mA / - Adj LDO regulator
    • GLF Integrated Power GLF1121H load switch
  10. DJI Mavic 3 Pro Chip ID, Drone Sensor Board: adım 10, 2 resimden 1. DJI Mavic 3 Pro Chip ID, Drone Sensor Board: adım 10, 2 resimden 2.
  11. DJI Mavic 3 Pro Chip ID, GNSS/ADS-B Board: adım 11, 2 resimden 1. DJI Mavic 3 Pro Chip ID, GNSS/ADS-B Board: adım 11, 2 resimden 2.
    • Likely Leadcore ADS-B ADS-B receiver
    • u-blox UBX-M10050-KB GNSS receiver
    • Maxscend MXDLN16TP GNSS LNA
    • Nexperia 74LVC1G08 single AND gate
CChin
6.909 İtibar
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 126
Son 30 gün: 550
Her zaman: 3,059
