Ana içeriğe geç
DJI Mavic Mini Flight Preparation
  1. DJI Mavic Mini Flight Preparation, Remove the camera gimbal cover: adım 1, 3 resimden 1. DJI Mavic Mini Flight Preparation, Remove the camera gimbal cover: adım 1, 3 resimden 2. DJI Mavic Mini Flight Preparation, Remove the camera gimbal cover: adım 1, 3 resimden 3.
    • Turn the rotor blades towards the battery compartment.
    • Grasp the cover tab with one finger, gently push it towards the camera and remove the cover.
    • Be careful with the gimbal and the camera as they are very sensitive.
  2. DJI Mavic Mini Flight Preparation, Unfold the front rotor arms: adım 2, 3 resimden 1. DJI Mavic Mini Flight Preparation, Unfold the front rotor arms: adım 2, 3 resimden 2. DJI Mavic Mini Flight Preparation, Unfold the front rotor arms: adım 2, 3 resimden 3.
    • Since the front rotor arms block the rear ones, it is absolutely necessary to unfold them first.
    • Hold the drone with one hand and unfold the rotor arm with the other.
    • Fold out the front arms only towards the camera and not up or down.
    • Repeat the process on the other side.
  3. DJI Mavic Mini Flight Preparation, Unfold rear rotor arms: adım 3, 3 resimden 1. DJI Mavic Mini Flight Preparation, Unfold rear rotor arms: adım 3, 3 resimden 2. DJI Mavic Mini Flight Preparation, Unfold rear rotor arms: adım 3, 3 resimden 3.
    • Turn the drone onto its back.
    • Fold out the rotor arm in an arc towards the battery compartment.
    • Repeat the process for the other rotor arm.
  4. DJI Mavic Mini Flight Preparation: adım 4, 2 resimden 1. DJI Mavic Mini Flight Preparation: adım 4, 2 resimden 2.
    • Unfold the phone holder.
    • Take the joysticks out of the holder and screw them in, in a clockwise direction.
  5. DJI Mavic Mini Flight Preparation, Switch on remote control: adım 5, 3 resimden 1. DJI Mavic Mini Flight Preparation, Switch on remote control: adım 5, 3 resimden 2. DJI Mavic Mini Flight Preparation, Switch on remote control: adım 5, 3 resimden 3.
    • Stecke dein Handy in die Halterung und verbinde es per Kabel mit der Fernbedienung.Put your phone in the cradle and connect it to the remote control via cable.
    • Make sure that Bluetooth and Wifi are enabled on your phone.
    • Press the On button once briefly, release it, and then press and hold until you hear a "beep" sound.
    • Always turn on the remote control before the drone.
  6. DJI Mavic Mini Flight Preparation, Turn on drone: adım 6, 2 resimden 1. DJI Mavic Mini Flight Preparation, Turn on drone: adım 6, 2 resimden 2.
    • Before you turn on the drone, you should slide a fully charged battery into the battery compartment.
    • Press the button on the bottom once briefly, let go, and then hold it down until you hear a "beep". (similar to the remote control).
    • Place the drone on a straight surface where it can take off.
    • Make sure there is a clear flight path above the drone and check your local laws governing drone flights.
  7. DJI Mavic Mini Flight Preparation, Connect to the drone: adım 7, 2 resimden 1. DJI Mavic Mini Flight Preparation, Connect to the drone: adım 7, 2 resimden 2.
    • With both devices turned on, open the "DJI Fly" app on your phone and wait for your drone to connect, you can tell because the app will show you a live image of your Drone.
    • If this does not happen follow the app's connection tutorial.
    • Now when the drone is connected to the remote control, you can make it go up by pressing the "start" button in the app.
    • Have fun flying!
Sonuç
Work through the steps in reverse order to repack your drone.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Mael
175 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 763
