Ana içeriğe geç
DJI Mavic Mini Propellers Replacement
Neye ihtiyacın var
  1. DJI Mavic Mini Propellers Replacement, Propellers: adım 1, 3 resimden 1. DJI Mavic Mini Propellers Replacement, Propellers: adım 1, 3 resimden 2. DJI Mavic Mini Propellers Replacement, Propellers: adım 1, 3 resimden 3.
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: adım 2, 3 resimden 1. DJI Mavic Mini Propellers Replacement: adım 2, 3 resimden 2. DJI Mavic Mini Propellers Replacement: adım 2, 3 resimden 3.
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: adım 3, 2 resimden 1. DJI Mavic Mini Propellers Replacement: adım 3, 2 resimden 2.
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
Sonuç
Chase Smith
147 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 1-2, Hunter Spring 2022 Clemson, Team 1-2, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G2
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,044
