Ana içeriğe geç
DJI Mavic Pro Propeller Replacement
Neye ihtiyacın var
  1. DJI Mavic Pro Propeller Replacement, Propellers: adım 1, 3 resimden 1. DJI Mavic Pro Propeller Replacement, Propellers: adım 1, 3 resimden 2. DJI Mavic Pro Propeller Replacement, Propellers: adım 1, 3 resimden 3.
    • Unfold your Dji Mavic Pro Drone.
  2. DJI Mavic Pro Propeller Replacement: adım 2, 3 resimden 1. DJI Mavic Pro Propeller Replacement: adım 2, 3 resimden 2. DJI Mavic Pro Propeller Replacement: adım 2, 3 resimden 3.
    • Push down slightly on the propeller you want to remove.
  3. DJI Mavic Pro Propeller Replacement: adım 3, 3 resimden 1. DJI Mavic Pro Propeller Replacement: adım 3, 3 resimden 2. DJI Mavic Pro Propeller Replacement: adım 3, 3 resimden 3.
    • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
    • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
  4. DJI Mavic Pro Propeller Replacement: adım 4, 3 resimden 1. DJI Mavic Pro Propeller Replacement: adım 4, 3 resimden 2. DJI Mavic Pro Propeller Replacement: adım 4, 3 resimden 3.
    • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
  5. DJI Mavic Pro Propeller Replacement: adım 5, 3 resimden 1. DJI Mavic Pro Propeller Replacement: adım 5, 3 resimden 2. DJI Mavic Pro Propeller Replacement: adım 5, 3 resimden 3.
    • Pull up the propeller to remove it.
  6. DJI Mavic Pro Propeller Replacement: adım 6, 3 resimden 1. DJI Mavic Pro Propeller Replacement: adım 6, 3 resimden 2. DJI Mavic Pro Propeller Replacement: adım 6, 3 resimden 3.
    • To replace the propellers, check to match the propellers with the arm of the drone.
    • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
  7. DJI Mavic Pro Propeller Replacement: adım 7, 3 resimden 1. DJI Mavic Pro Propeller Replacement: adım 7, 3 resimden 2. DJI Mavic Pro Propeller Replacement: adım 7, 3 resimden 3.
    • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
    • Push the propeller down.
  8. DJI Mavic Pro Propeller Replacement: adım 8, 2 resimden 1. DJI Mavic Pro Propeller Replacement: adım 8, 2 resimden 2.
    • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
    • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
  9. DJI Mavic Pro Propeller Replacement: adım 9, 2 resimden 1. DJI Mavic Pro Propeller Replacement: adım 9, 2 resimden 2.
    • Check to see if the propeller is properly locked into place by slightly pulling it up.
    • If it is locked, then you can safely fly your drone.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 110
Her zaman: 4,527
