Ana içeriğe geç
DJI Mavic Pro Upper Shell Replacement
Neye ihtiyacın var
    1. DJI Mavic Pro Upper Shell Replacement, Battery: adım 1, 3 resimden 1. DJI Mavic Pro Upper Shell Replacement, Battery: adım 1, 3 resimden 2. DJI Mavic Pro Upper Shell Replacement, Battery: adım 1, 3 resimden 3.
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Mavic Pro Upper Shell Replacement, Upper Shell: adım 2, 1 resimden 1.
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Mavic Pro Upper Shell Replacement: adım 3, 1 resimden 1.
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Mavic Pro Upper Shell Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. DJI Mavic Pro Upper Shell Replacement: adım 5, 1 resimden 1.
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    5. DJI Mavic Pro Upper Shell Replacement: adım 6, 1 resimden 1.
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      FixBot'a Sor
      Yorum Ekle
    6. DJI Mavic Pro Upper Shell Replacement: adım 7, 1 resimden 1.
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mondona Behroozian
1.716 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S17G3
4 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Yanıt Paylaş
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 72
Her zaman: 6,757
